Wifi Radio Cost Breakdown
June 10th, 2009 by JeffMany people have asked me for a cost breakdown of my Wifi Radio project. Well, here it is!
I added a link to possible sources for as many parts as I could. However, there were a few things I scrounged from local surplus electronics stores and couldn’t easily find a good equivalent online. I’m not expecting everyone to copy my design exactly (not everyone has a woodworking shop at their disposal), so use these numbers as a rough estimate only.
If you shop around you should be able to beat the listed prices on many items, so I see this as sort of a worst case scenario.
To flash the wireless router and create a minimal radio (with no user interface), you will need:
- Asus WL-520gU wireless router
– currently $34.99 with MiR
- SYBA SD-CM-UAUD USB Stereo Audio Adapter
– $7.99
- FTDI USB TTL-232 3.3V serial adapter cable – $20
- 0.1″ Break-away Header Strip – $2.50
Total: $65.48
To make the LCD display and tuner interface, you’ll also need:
- USBtinyISP AVR programmer – $22
- 16×2 Character LCD (5V) – $13.95
- ATmega168 microcontroller – $4.11
- 28-pin socket – $1.50
- 16MHz crystal – $1.50
- 2 x 22pF capacitors – $0.25 ea.
- Contrast trimpot, 1k (or similar) – ~$0.75
- Tuner potentiometer, 10k – $1.40
- Reset microswitch – $0.35
- Serial connector (cut an old CD-ROM audio cable in half) – $0
- Protoboard – $5
- Some hookup wire - $0
- 0.1uF bypass cap and a few resistors (10Ohm and 1K) - around $1 at any decent electronics store
Total: $52.06
(This is on the high end, the interface can certainly be built for less by using scrounged/surplus components.)
To make the finished radio, add:
- Volume and tune knobs – ~$2 @ HSC
- Cool tuner knob – $8.55
- 5V/12V power supply brick – $10 @ Weird Stuff
- 5-pin mini-DIN power connector – ~$3 @ HSC
- Power switch – ~$1 @ HSC
- Cheap set of PC speakers (gutted for the speakers and amplifier) – $5 @ Weird Stuff
Total: $29.55
Oh yeah, and I almost forgot…
- An awesome friend named Tony with a full woodworking shop in his garage who will make you a killer wooden enclosure for free – $priceless
Grand total (excluding the box) – $147.09
If you take out the cost of the development tools, namely the FTDI cable and the USBtinyISP, the total comes out to $105 (without the box).
By scrounging materials and using parts from your junkbox you should be able to reduce that figure even more, but obviously the grand total hinges on what kind of enclosure you use. Not everyone has a friend with serious woodworking skills willing to donate time and materials, but use this as an excuse to get creative.
I wanted a box that showcased the time and effort that I spent on the electronics inside, but that doesn’t mean an old boombox from the Salvation Army couldn’t work just as well.
When I first started this project, my goal was to keep the total parts cost under $100. On paper, it looks like I came pretty close to that, thanks to the donated box and excluding the reusable development tools like the FTDI cable and AVR programmer. To be honest, I probably spent twice that amount on spare power supplies, extra knobs, a second router to bring to NOTACON, and a bunch of other stuff that I didn’t end up using in the final project. But I’m pretty ok with that. I think this just highlights the fact that:
If you just want a Wifi Radio, it will always be cheaper to buy one off the shelf. But if you make your own, it will be infinitely more rewarding.
It certainly has been for me.
Tags: adafruit, Asus, BOM, HSC, Newegg, sparkfun, Weird Stuff, wifiradio, WL-520GU
You know, if you could add an iPod dock, the cost would be well worth it
I can build boxes for $500 each
You don’t really need the usb serial adaptor and header board, that’ll take $20 off the price
Though it is nice to have…
Madox – You’re right, but it is a really handy troubleshooting tool. Without it, you are flying blind for the first few steps.
I’m still thinking about your last comment. It will always be cheaper to buy… One generation back, it was cheaper to build which is one reason why Heathkit was so popular. I sometimes work with children and it is hard to get them interested because nothing we build seems that impressive.
Thanks for the post.
“that doesn’t mean an old boombox from the Salvation Army couldn’t work just as well.”
… in fact I reckon one of these in a gutted-out boombox would have a certain Retro 80s chic – especially given the instant deification of MJ over the last few days.
