HV Rescue Shields are back in stock!
AVR HV Rescue Shield
It took a couple weeks longer than I expected, but HV Rescue Shield kits are back in stock now.
Order yours today!
4 thoughts on “HV Rescue Shields are back in stock!”
  1. Hi i have made the arduino shield using the previous version. unfortunately it is not working. i tried with a bricked chip, it did not fix the chip; i tried with a good chip only to see if the hvpp is working or not, but the good one’s fuse also remained unaltered. i have checked the connection and seems ok.
    few pointers i wanted to mention:
    1. I am using a pc atx psu to get the 12vdc.
    2. between 12 v and collector of 2n2222 i am using 2.2k instead of 1k resistor.
    3. Not using any protection resistors.
    Please help
  2. We could also call this an “I/O lines expander” – if you’re not dependent on ISCP, then you can free up the Reset pin and get that 6th I/O line you always wanted 🙂 (speaking in terms of the smaller chips like Attiny13 that always seem to have one I/O less than you actually need)
    1. ElectroNick – That is an excellent suggestion – on low pincount parts you often need to take advantage of every IO pin you can get.
